- Auto-detect and centralized management, up to 500 CAPs
- License-free management reduces the OPEX of enterprise network
- Easy deployment without changing the existing network topology
- Unified configuration of wireless networks, support mapping of SSID and VLAN
- Support MAC authentication, portal authentication
- Dual-link back up for management safety
Efficient management
Designed to handle up to 500 manageable access points, the TP-Link AC500 Wireless Controller offers a scalable solution for growing businesses, ensuring seamless connectivity across all devices. -
Robust security
With support for WPA and WPA2 encryption algorithms alongside RADIUS and SSID authentication methods, this device provides a secure networking environment, safeguarding sensitive data from unauthorized access. -
Advanced connectivity
Featuring five 1000Base-T ports and one console port, the AC500 facilitates high-speed, reliable connections, making it ideal for handling substantial data traffic efficiently. -
Comprehensive control
Supporting features like VLAN support, SSID to VLAN mapping, and Wi-Fi Multimedia (WMM) support, the AC500 allows for detailed network management and prioritization of data flow. -
Durable and reliable
Engineered for performance, this rack-mountable network management device operates effectively within a wide range of temperatures and humidity, ensuring reliability in various operating environments.
- TP-Link AC500 Wireless Controller - network management device
- Network management device
- Form Factor
- Rack-mountable - 1U
- Processor
- 1 x MIPS64 1 GHz
- RAM
- 512 MB
- Flash Memory
- 32 MB
- Ports Qty
- 5
- Data Link Protocol
- Capacity
- Manageable access points: 500
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 22 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 44 cm
- 22 cm
- 4.4 cm
Processor / Memory / Storage
- Processors Installed
- 1 x MIPS64 1 GHz
- RAM
- 512 MB DDR3 SDRAM
- Flash Memory
- 32 MB
- Form Factor
- Rack-mountable
- Ports Qty
- 5
- Connectivity Technology
- Wired
- Capacity
- Status Indicators
- Power, system, link/activity
- Load balancing, VLAN support, firmware upgradable, Wi-Fi Multimedia (WMM) support, DHCP server, Multiple SSID support, fanless, system log, SSID to VLAN mapping
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.1x
- 5 x 1000Base-T - RJ-45 , 1 x console - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
