TP-LINK's AC450 Wireless Nano USB Adapter, the Archer T1U allows you to connect a desktop or laptop computer to a wireless network and achieve speeds of up to 433Mbps. This miniature adapter is designed to be as convenient and unobtrusive as possible, while also including attractive features such as advanced wireless encryption, easy installation.
Miniature design - plug in and forget
The adaptor's size and sleek design allow it to be inserted into any USB port and left there for extended periods of time. There's no need to worry about blocking adjacent USB ports and, because the tiny device sits flush against the USB port, there is almost no chance that the adapter will fall out when you are moving or storing your device. -
Fast, stable Wi-Fi
The Archer T1U provides Wi-Fi data transmission rates of up to 433Mbps on the 5GHz band, making it ideal for streaming video and making audio calls over the Internet. By utilizing the uncluttered 5GHz band, the Archer T1U efficiently avoids wireless signal interference and ensures a stable Wi-Fi connection.
- TP-Link Archer T1U - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.86 cm x 1.5 cm x 0.71 cm
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 433 Mbps
- Frequency Band
- 5 GHz
- IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac
- System Requirements
- Microsoft Windows XP / 7 / 8 / 8.1
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM
- 433 Mbps
- Line Coding Format
- DBPSK, DQPSK, 64 QAM, 256 QAM, 16 QAM, OFDM
- Frequency Band
- 5 GHz
- Status Indicators
- Status
- Ad-Hoc Mode, WPS
Aerial
- Antenna
- Internal
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 1.86 cm
- 1.5 cm
- 0.71 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
