TP LINK AC450 Wireless Nano USB Adapter
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: BRPWWS00 Mfr#: Archer T1U
  • IEEE 802.11n
TP-LINK's AC450 Wireless Nano USB Adapter, the Archer T1U allows you to connect a desktop or laptop computer to a wireless network and achieve speeds of up to 433Mbps. This miniature adapter is designed to be as convenient and unobtrusive as possible, while also including attractive features such as advanced wireless encryption, easy installation.
  • Miniature design - plug in and forget
    The adaptor's size and sleek design allow it to be inserted into any USB port and left there for extended periods of time. There's no need to worry about blocking adjacent USB ports and, because the tiny device sits flush against the USB port, there is almost no chance that the adapter will fall out when you are moving or storing your device.
  • Fast, stable Wi-Fi
    The Archer T1U provides Wi-Fi data transmission rates of up to 433Mbps on the 5GHz band, making it ideal for streaming video and making audio calls over the Internet. By utilizing the uncluttered 5GHz band, the Archer T1U efficiently avoids wireless signal interference and ensures a stable Wi-Fi connection.
TP-Link Archer T1U - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.86 cm x 1.5 cm x 0.71 cm
Wi-Fi 5
Data Transfer Rate
433 Mbps
Frequency Band
5 GHz
IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows XP / 7 / 8 / 8.1
Network adapter
External
USB 2.0
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
433 Mbps
Line Coding Format
DBPSK, DQPSK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
5 GHz
Status Indicators
Status
Ad-Hoc Mode, WPS
Aerial
Antenna
Internal
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
1.86 cm
1.5 cm
0.71 cm
10 - 90% (non-condensing)
