Archer C3200 uses Tri-Band Smart Connect technology to run three separate Wi-Fi channels at once, creating a network that can connect to more devices without a trade-off in performance. Smart Connect helps devices run even faster by assigning them to the best available channel to balance network demand. And with the ultra fast combined Wi-Fi speed, the Archer C3200 lets you simultaneously game online and stream video in 4K Ultra HD across multiple devices without lag. Six high-performance external antennas greatly increase the Archer C3200’s range and signal stability. Beamforming technology further improves the router’s coverage by helping it locate wireless devices to form stronger, more reliable connections.
More Wi-Fi for more devices
The Archer C3200 uses Tri-Band technology to run three separate Wi-Fi channels at once, creating a network that can connect to more devices without a trade-off in performance. Smart Connect helps devices run even faster by assigning them to the best available channel to balance network demand. -
Seamless streaming and gaming
With the ultra fast combined Wi-Fi speed, the Archer C3200 lets you simultaneously game online and stream video in 4K Ultra HD across multiple devices without lag. -
Maximum coverage and stability
Six high-performance external antennas greatly increase the Archer C3200’s range and signal stability. Beamforming technology further improves the router’s coverage by helping it locate wireless devices to form stronger, more reliable connections. -
Run all your devices at once
A powerful CPU and three co-processors easily handle the demand made on the Archer C3200’s network when multiple users are browsing, streaming, and gaming all at the same time. -
Lightning-fast wired performance
External hard drives can connect directly to the Archer C3200 via its USB 3.0 and 2.0 ports, making it easy to share files, photos, music, and video across your network. The Archer C3200 is also equipped with four Gigabit Ethernet ports that enable blazing wired speeds, helping connected gaming consoles, PCs, and smart TVs achieve their best performance. -
Easy setup and use
Set up the Archer C3200 in minutes thanks to its intuitive web interface. Guest Network feature provides visitors width Wi-Fi access separate from your main network, while parental controls allow you to manage when and how connected devices can access the Internet.
- TP-Link Archer C3200 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Data Transfer Rate
- 3200 Mbps
- PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
- Dynamic DNS server, print server, IPv6 support, parental control, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, DHCP client, Tri-Band Smart Connect technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 20 cm x 20 cm x 3.9 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 3200 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Processor
- 1 GHz
- Built-in Devices
- Led panel
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 6
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 20 cm
- 20 cm
- 3.9 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
