TP LINK AC2800 Wireless MU-MIMO VDSL/ADSL Modem Router
Quicklinx: DHJWWS00 Mfr#: ARCHER VR2800
Type: Wireless router
Connection Type: ADSL, ADSL2+, VDSL2 and Fibre
Standards: IEEE 802.11n, IEEE 802.11g, Ethernet, Fast Ethernet + 4 more
Speed: 100Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£153.86 ex VAT
£184.63 inc VAT
MU-MIMO technology serves several devices at once, reducing wait time, increasing Wi-Fi throughput for every device, and making each stream more efficient. As a powerful DSL modem router, the Archer VR2800 supports super fast VDSL or ADSL broadband, as well a variety of other connection types. The LAN/WAN port accepts connections from cable modem or fiber modem, and both of the USB 3.0 ports support 3G/4G dongle connections for a perfect main or backup internet connection. Beamforming technology locates the connected devices and further improves the Archer VR2800's range and the signal strength to each mobile device, delivering a more reliable and efficient wireless connection. Separate Wi-Fi bands enable more devices to connect to your network without a drop in performance.
  • MU-MIMO
  • Versatile connectivity
  • Wi-Fi with Beamforming
  • Simultaneous dual band
TP-Link Archer VR2800 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
NAT support, ALG support, dynamic DNS server, print server, MAC address filtering, IPv6 support, parental control, IP address filtering, DDos attack prevention, WMM support, QoS, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, DHCP relay, SPIF, DHCP client, VPN Server, MU-MIMO technology, beamforming technology, Broadcom NitroQAM technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
26.38 cm x 19.78 cm x 3.73 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS, RCM
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.998.4, ITU G.993.5
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable , 1 x phone cable , 1 x phone splitter
26.38 cm
19.78 cm
3.73 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Speed: 100Mbps
Brand: TP LINK
