TP LINK AC1750 Wireless Gigabit Ceiling Mount Access Point
Quicklinx: FZ6BWS00 Mfr#: EAP265HD
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11g, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b + 1 more
Compatibility: [N/A]
  • IEEE 802.11n
19 In Stock
£99.03 ex VAT
£118.83 inc VAT
Omada's Software Defined Networking (SDN) platform integrates network devices, including access points, switches, and gateways, providing 100% centralized cloud management. Omada creates a highly scalable network - all controlled from a single interface. Seamless wireless and wired connections are provided, ideal for use in hospitality, education, retail, offices, and more.
  • Fast dual-band Wi-Fi
    Simultaneous 450 Mbps on 2.4 GHz and 1300 Mbps on 5 GHz totals 1750 Mbps Wi-Fi speeds.
  • High-density connectivity
    MU-MIMO, Load Balance, and professional antennas improve capacity in high-density environments to connect more devices simultaneously.
  • Integrated into Omada SDN
    Zero-Touch Provisioning (ZTP), Centralized Cloud Management, and Intelligent Monitoring.
  • Centralized management
    Cloud access and Omada app for ultra convenience and easy management.
  • Seamless roaming
    Even video streams and voice calls are unaffected as users move between locations.
  • PoE support
    Support both standard 802.3af/at and Passive PoE (PoE adapter included) for flexible installations.
  • Secure guest network
    Along with multiple authentication options (SMS/Facebook Wi-Fi/Voucher, etc.) and abundant wireless security technologies.
TP-Link EAP265 HD AC1750 Wireless MU-MIMO Gigabit Ceiling Mount Access Point - radio access point - Wi-Fi 5
Radio access point
Wall / ceiling mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
Wall mounting kit, ceiling mounting kit, Gigabit Passive PoE Adapter
Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE
20.55 cm x 18.15 cm x 3.71 cm
Radio access point
20.55 cm
18.15 cm
3.71 cm
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
Wi-Fi Rating
AC1750
Manageable, E-mail alert, MAC address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, rogue access point detection, Captive Portal, security lock slot (cable lock sold separately), Transmit Power Control (TPC), MU-MIMO technology, beamforming technology, passive PoE supported, band steering, SSID to VLAN mapping, rate limit, Wireless Scheduler, seamless roaming, Airtime Fairness, schedule reboot, load balance network mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
Secure Shell (SSH)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45
FCC, RoHS
PoE
12.3 Watt
10 - 90% (non-condensing)
Speed: 1750Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Antennas: [N/A]
Brand: TP LINK
