TP LINK AC1750 Wi-Fi Range Extender
Quicklinx: BLQ7WS00 Mfr#: RE450
Type: Wi-Fi range extender
Connectivity: Wired, Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11g, Fast Ethernet, IEEE 802.11ac, IEEE 802.11b + 4 more
Compatibility: Unix, Mac, PC
  • IEEE 802.11n
32 In Stock
£41.66 ex VAT
£49.99 inc VAT
Boost Your Wi-Fi Coverage Up to 10,000 sq ft*
Tired of Wi-Fi "dead zones"? The TP-LINK AC1750 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can’t reach on its own. The device also reduces signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
Super-Fast Speed Next Generation AC Wi-Fi
TP-LINK's RE450 comes with next generation 802.11AC Wi-Fi technology, it's 3 times faster than the standard 802.11n speeds. The RE450 delivers fast speeds of dual band Wi-Fi up to 1750 Mbps, providing reliable connections for bandwidth-intensive tasks like HD/4K streaming, lag free gaming, large file downloads.
Gigabit Wired Speed
A gigabit Ethernet port turns the extender into a wireless bridge, letting you connect a wired device like a Blu-ray player, gaming console, DVR, or smart TV to your Wi-Fi network.
Easy Installation & Quick Position - Easy Installation with RE Button
The extender RE450 works with any standard wireless router. Instantly connect the RE450 to a router by pressing the extender’s RE button followed by the router’s WPS button (if available). Once connected with an existing router, you can take RE450 to an ideal place, no more further configurations.
Quick Positioning with Intelligent Signal Indicator
The Intelligent signal light can help to find the best location to place the extender.
High Performance External Antennas
Three external dual band antennas (3 x 2dBi for 2.4GHz and 3 x 3dBi for 5GHz) boost your wireless coverage and reliability, helping your devices stay connected anywhere your network reaches
High Speed Mode
High Speed mode maximizes overall performance by combining the bandwidth of both the 5GHz and 2.4GHz channels to create a lightning-fast connection with one band sending data and the other receiving it
TP-Link RE450 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom, United States, Europe
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
16.3 cm x 7.64 cm x 6.65 cm
16.3 cm
7.64 cm
6.65 cm
External
Wireless, wired
Data Transfer Rate
1750 Mbps
Frequency Band
2.4 GHz, 5 GHz
Reset button, High Speed Mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Aerial
Antenna
External integrated
Antenna Qty
3
Gain Level
3 dBi
1 x 1000Base-T - RJ-45
1 x network cable
FCC, RoHS
Internal power supply
9 Watt
30 °C
10 - 90% (non-condensing)
BLQ7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
BLQ7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
Connectivity: Wired
Connectivity: Wireless
Speed: 1750Mbps
Protocol: Fast Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: IEEE 802.11n
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
Antennas: 3
Brand: TP LINK
