TP LINK AC1750  Wireless GB Ceiling Mount Accept Point
Quicklinx: D96ZWS00 Mfr#: EAP245
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: [N/A]
  • IEEE 802.11n
3 In Stock
£65.19 ex VAT
£78.22 inc VAT
Standard delivery Delivered within 3-5 working days
The 802.11ac Wi-Fi combined with advanced 3x3 MIMO technology ensures the EAP245 superior Wi-Fi speeds and coverage.
  • Flexible deployment
    The EAP's low-profile design and easy mount chassis make it easy to install on any wall or ceiling surface and allow it to blend in with most interior decorating styles. EAP devices also support PoE, making deployment effortless and flexible.
  • Wi-Fi for multi-user business environment
    The business-grade 11ac Wi-Fi solution is engineered to handle heavy multi-user usage in large areas without encountering the same stability issues found with standard routers and access points purposed for home use. It's the perfect fit for motels, salons, chain-stores, schools, and restaurants.
TP-Link Omada EAP245 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs (2.4 Ghz): 8 , Maximum number of configured SSIDs (5 Ghz): 8
Wall mounting kit, ceiling mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE+
18 cm x 18 cm x 4.75 cm
Radio access point
18 cm
18 cm
4.75 cm
External
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, CLI
Frequency Band
2.4 GHz, 5 GHz
Load balancing, VLAN support, Syslog support, manageable, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
Gain Level
4 dBi
1 x 1000Base-T (PoE+) - RJ-45
UL, FCC, RoHS
PoE+
External power adapter
12.7 Watt
Software Included
Drivers & Utilities
Limited warranty - lifetime
10 - 90% (non-condensing)
Speed: 1750Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Antennas: 6
Brand: TP LINK
