TP LINK AC1350 Wless Dual Band Router V2
Quicklinx: FVB5WS00 Mfr#: Archer C60
  • IEEE 802.11n
£49.88 ex VAT
£59.85 inc VAT
The Archer C60 comes with the latest wireless standard - 802.11ac. This advanced Wi-Fi is designed for high-traffic online activities and can help to run applications at triple the speed of the previous 802.11n standard. The result: faster, stronger and more capable Wi-Fi to unleash all your wireless devices.
  • Fast, concurrent dual band Wi-Fi
    The Archer C60 provides you with simultaneous dual band Wi-Fi connections. 3x3 MIMO creates fast and stable Wi-Fi at speeds of 450 Mbps, making it perfect for daily applications like sending emails, browsing the web or listening to music. 5 GHz band provides up to 867 Mbps Wi-Fi for latency-sensitive entertainment so you can stream HD video, play online games and hold video chats all at the same time, without delay.
  • Arranged Coverage, Enhanced Stability
    Archer C60's innovative design includes five antennas, three at 2.4GHz and two at 5 GHz. These have been arranged alternately to optimize the dual band 802.11ac Wi-Fi, creating a transmission with maximized coverage, minimized interference. Disorganized Antenna LayoutAntennas transmitting at the same frequency are placed too closely, causing interference and signal instability. Organized Antenna ArrangementAntennas transmitting at the same frequency are placed in alternate order, reducing interference for a more pure, stable dual band connection.
  • Easy parental control
    Supervise children and staff with responsible access, controlled by parents or administrators. Use URL blocking to easily set up a black or white list and limit the level of web access.
  • Guest network access
    Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
  • Impeccable design
    To match its advanced features, the Archer C60 introduces an elegant texture and color to fit the stylish décor of your home.
  • Easy setup and management
    Set up the Archer C60 in minutes thanks to its intuitive web interface. Configuration is also in the palm of your hands with TP-LINK's powerful app, Tether, the easiest way to access and manage your router through your smartphone.
TP-Link Archer C60 AC1350 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.35 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
DoS attack prevention, print server, MAC address filtering, IPv6 support, WDS support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
23 cm x 14.4 cm x 3.7 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.35 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1350
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Built-in Devices
Led panel
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
5
External power adapter
1 x network cable
Software Included
Drivers & Utilities
23 cm
14.4 cm
3.7 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ac
Speed: 1.35Gbps
Brand: TP LINK
