TP LINK AC1300 Wireless Dual Band PCI Express Adapter
Quicklinx: BLYHWS00 Mfr#: ARCHER T6E
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n + 1 more
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£38.91 ex VAT
£46.69 inc VAT
Easy Installation – Upgrade your desktop system easily by plugging the Archer T6E Wi-Fi adapter into an available PCI-E slot
Hi-Speed Wi-Fi – Up to 1300Mbps Wi-Fi speeds (867Mbps on 5GHz band or 400Mpbs on 2.4GHz band)
802.11ac Dual Band – 3 times faster than the 802.11n standard, perfect for hi-intensity network usage
Backward Compatibility – With support for 802.11 a/b/g/n standards
Broad Wireless Range – 2 external antennas ensure a greater range of Wi-Fi connection and stability
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer T6E supports the next generation Wi-Fi standard - IEEE 802.11ac, offering transfer rates that are 3 times faster than wireless N speeds. Easily upgrade your desktop system by simply slotting the Wi-Fi adapter into an available PCI-E slot.
AC1300 – Selectable Dual Band Speeds 867/400Mbps
The Archer T6E provides high-speed Wi-Fi of up to 867Mbps over 5GHz, perfect for HD video streaming and lag-free online gaming. Additionally, the 2.4GHz 400Mbps Wi-Fi band is ideal for standard network/internet usage such as web surfing.
Heat Sink for Better Stability
The Heat Sink helps to dissipate heat generated by the adapter, which in turn increases performance and improves stability. What’s more, lower temperatures ensure an increased adapter lifespan.
External Antennas
External antennas for easy alignment to achieve the best signal.
Operating System
Supports Windows 8.1/8/7/XP 32/64bit.
Easy to Install
A friendly user interface Utility on a CD for simple installation.
Advanced Security
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders.
  • 802.11ac - the next generation of Wi-Fi
  • AC1300 - selectable dual band speeds 867/400Mbps
    The Archer T6E provides high-speed Wi-Fi of up to 867Mbps over 5GHz, perfect for HD video streaming and lag-free online gaming. Additionally, the 2.4GHz 400Mbps Wi-Fi band is ideal for standard network/Internet usage such as web surfing.
  • Heat sink for better stability
    The heat sink helps to dissipate heat generated by the adapter, which in turn increases performance and improves stability. What's more, lower temperatures ensure an increased adapter lifespan.
TP-Link Archer T6E - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
2.15 cm x 11.52 cm x 12.08 cm
Wi-Fi 5
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
Network adapter
Plug-in card
PCI Express
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
1300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Aerial
Antenna
External detachable
Antenna Qty
2
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
FCC, RoHS
2.15 cm
11.52 cm
12.08 cm
Limited warranty - parts and labour - 2 years
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: TP LINK
