TP LINK AC1200 4G LTE Advanced Cat6 Gigabit Router
Quicklinx: FNDPWS00 Mfr#: Archer MR600
Type: Wireless router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n + 4 more
Speed: 1.2Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
23 In Stock
£104.34 ex VAT
£125.20 inc VAT
Plug your SIM card and enjoy HD movies without interruption, downloading files in seconds, and smooth online gaming.
  • Fully Gigabit ports
    Fully Gigabit Ethernet ports provide warp speeds and reliable connections for high-intensive wired devices such as your smart TV, game console, NAS, and more.
  • Wi-Fi where you need it
    Enjoy unmatched convenience and versatility. Tested in the field for years to ensure universal compatibility with 2 advanced LTE antennas to deliver a smooth connection.
  • Reliable access
    Easily share a 3G/4G connection with many wireless devices, such as phones, tablets, and laptops, at the same time. 4 LAN ports stand ready to provide Internet for wired devices like desktop computers.
TP-Link Archer MR600 4G+ Cat6 AC1200 Wireless Dual Band - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem - 3-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
UMTS, HSPA, DC-HSPA+, FDD LTE, TDD LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
DoS attack prevention, IPv6 support, parental control, IP address filtering, port forwarding, bandwidth control, IPv4 support, domain filter
22.9 cm x 16 cm x 3.7 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, RoHS
Communications
Wireless cellular modem
WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Expansion Slots
1 (total) / 1 (free) x Micro-SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
1 x network cable
22.9 cm
16 cm
3.7 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 1.2Gbps
Brand: TP LINK
