TP LINK 8-Port Multi-Gigabit Desktop Switch
Quicklinx: G6X2WS00 Mfr#: TL-SG108-M2
Type: 2.5 Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: No
£84.72 ex VAT
£101.66 inc VAT
As the flagship 2.5G products, the 5/8-Port desktop switches with 5/8x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices and provide up to 25/40 Gbps of switching capacity. Auto-negotiation 3-speed (100Mb/1G/2.5G) connections sense the link speeds and intelligently adjust for compatibility and optimal performance for all your devices, including 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, 2.5G Wi-Fi 6 AP, 4K video, desktop, and more.
  • Just Plug and Play for Internet access
    A plug-and-play design allows for easy deployment without the need for a technician. Auto MDI/MDIX eliminates the need for crossover cables.
  • Silent operation with industry-leading fanless design
    The revolutionary fanless design ensures unprecedented silent operation, ideal for any home or business. Durable metal casing, desktop/wall-mounting design and professional heat dissipation design are well-suited for different environments.
  • 2.5G super-fast speeds without changing cables
    Flawlessly integrated into existing gigabit Ethernet network infrastructures, 2.5× faster speeds with regular Cat5e Ethernet cables, without the need to upgrade to Cat6 wiring, reducing wiring costs and hassle.
  • Ideal for small and home office
    Work at the office or home with lightning-fast connections to workstations, desktop computers, and Wi-Fi 6 access points.
  • Powerful performance for smooth LAN parties
    Never host a laggy LAN party again. Experience the unparalleled speed and lower latency, and prioritize gaming traffic with QoS. Let's begin the unprecedented smooth game!
TP-Link TL-SG108-M2 - V1 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Ports
8 x 100/1000/2.5G
Performance
Switching capacity: 40 Gbps , Packet forwarding rate: 29.8 Mpps
Packet buffer size: 1.5 MB
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, metal housing, DSCP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3bz
22.6 cm x 13.1 cm x 3.5 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Ports
8 x 100/1000/2.5G
Performance
16K entries
Jumbo Frame Support
10KB
Status Indicators
Power, status
8 x 100/1000/2.5G RJ-45
External power adapter
Power Provided
DC 12 V - 1 A
Plug and Play, FCC, RoHS
22.6 cm
13.1 cm
3.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: TP LINK
