The Passive PoE switch TL-RP108GE has seven gigabit PoE input ports that allow it to receive power from user outlets via PoE injectors. Equipped with one PoE output port, the switch can supply power to CPEs and similar devices via Port 8. The DC output port supports both 5 V and 12 V optional output voltage and can be used to power devices like ONTs. With data switching and PoE integrated into a single unit, TL-RP108GE saves space, minimizes cabling, and eliminates the need for dedicated electrical outlets - lowering deployment costs and simplifying installation for PoE-capable devices.
Enhanced connectivity
With 7 PoE input ports and 1 PoE output port, the TL-RP108GE offers versatile connectivity options for various devices, ensuring seamless integration into any network setup. -
Robust performance
Boasting a switching capacity of 16 Gbps and a packet forwarding rate of 11.9 Mbps, this switch is engineered to handle high volumes of traffic, maintaining efficient data transmission across the network. -
Advanced networking features
Features such as VLAN support, Quality of Service (QoS), and IGMP snooping enhance network management and prioritize traffic, ensuring critical data is delivered swiftly and reliably. -
Durable and reliable
Designed to operate in a wide range of temperatures and humidity levels, the TL-RP108GE is built to withstand harsh environments, ensuring long-term reliability and performance. -
Eco-friendly design
Compliant with FCC and RoHS standards, this switch not only meets regulatory requirements but also minimizes its environmental footprint, making it a responsible choice for eco-conscious businesses.
- TP-Link TL-RP108GE - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 7 x 10/100/1000 (PoE input) + 1 x 10/100/1000 (PoE output)
- Power Over Ethernet (PoE)
- Reverse PoE
- Performance
- Switching capacity: 16 Gbps , Packet forwarding rate: 11.9 Mbps
- Capacity
- Virtual interfaces (VLANs): 32
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 16KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Full duplex capability, auto-negotiation, VLAN support, IGMP snooping, port mirroring, store and forward, QoS, Cable Diagnostics Function, loop prevention, DSCP support, Storm Control, rate limit, Static Link Aggregation, VLAN Tagging, DSCP prioritisation
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3p, IEEE 802.3q
- 15.8 cm x 9.91 cm x 2.5 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- Reverse PoE
- Performance
- Capacity
- 4K entries
- 16KB
- Routing Protocol
- Status Indicators
- Power, link/activity
- 7 x 1000Base-T RJ-45 PoE input , 1 x 1000Base-T RJ-45 PoE output
- 32.74 watt
- Included Accessories
- Rubber feet
- FCC, RoHS
- OS Required
- 15.8 cm
- 9.91 cm
- 2.5 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
