The TP-Link 8-Port 10/100/1000Mbps Desktop Switch provides you an easy way to make the transition to Gigabit Ethernet. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Plug and Play design, with no configuration required, makes the product easy to use. Moreover, TL-SG108S adopts lower power consumption design. With the innovative energy-efficient technology, the TL-SG108S can save power consumption, making it an eco-friendly solution for your home or office network.
Gigabit switch
Featured with 8 10/100/1000Mbps ports, TL-SG108S greatly expands your network capacity, enabling instant large files transferring. So, power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. -
Go green with your Ethernet
You now have the choice to go green when upgrading to a gigabit network! This new generation TL-SG108S 8-Port 10/100/1000Mbps Desktop Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. -
Traffic optimization
802.1p and DSCP QoS enable smooth latency-sensitive traffic such as voice and video, and IGMP Snooping optimizes the Multicast data stream. -
Easy to use
The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance. Moreover, fanless design ensures quiet operation.
 - TP-Link TL-SG108S - switch - 8 ports
 - Switch - 8 ports
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
 - Forwarding performance: 11.9 Mpps
- MAC Address Table Size
 - 4K entries
- Jumbo Frame Support
 - 16KB
 - Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, QoS, Green Ethernet, fanless
 - IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
 - 15.8 cm x 10.1 cm x 2.5 cm
 - Switch - 8 ports
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
 - 4K entries
 - 16KB
- Status Indicators
 - Power, link/activity
 - 8 x 1000Base-T RJ-45
- Power Device
 - External power adapter
 - 3.3 Watt
- Included Accessories
 - Rubber feet
 - FCC, RoHS
 - 15.8 cm
 - 10.1 cm
 - 2.5 cm
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 90% (non-condensing)
