TL-SF1008D 8-port 10/100Mbps Fast Ethernet Switch provides 8 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports. The Switch is Plug-and-Play and each port can be used as general ports or Uplink ports and can be simply plugged into a server, a hub or a switch, using straight cable or crossover cable.
The TP-LINK TL-SF1008D 8-port 10/100M Fast Ethernet Switch provides you with a low-cost, easy-to-use, high-performance, seamless and standard upgrade to improve your old network to a 100Mbps network. It will boost your network performance up to full duplex data transfer. Its wire-speed switching that forwards packets can be as fast as the speed that your network delivers those packets to them.
 - TP-Link TL-SF1008D 8-Port 10/100Mbps Desktop Switch - switch - 8 ports
 - Switch - 8 ports
- Subtype
 - Fast Ethernet
- Ports
 - 8 x 10/100
- MAC Address Table Size
 - 1K entries
 - Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
 - (50/60 Hz)
 - 14 cm x 8.5 cm x 3.3 cm
 - Switch - 8 ports
- Enclosure Type
 - Desktop
- Subtype
 - Fast Ethernet
- Ports
 - 8 x 10/100
 - 1K entries
- Status Indicators
 - Power, link/activity
 - 8 x 100Base-TX RJ-45
- Power Device
 - External power adapter
- Voltage Required
 - (50/60 Hz)
 - FCC
 - 14 cm
 - 8.5 cm
 - 3.3 cm
 - 0 °C
 - 40 °C
 - 10 - 90%
                        C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
                        C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
