TP LINK 8-port 10/100 mini Desk Switch
Quicklinx: 77SCWS00 Mfr#: TL-SF1008D
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: No
POE: No
More than 50 In Stock
£8.67 ex VAT
£10.40 inc VAT
TL-SF1008D 8-port 10/100Mbps Fast Ethernet Switch provides 8 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports. The Switch is Plug-and-Play and each port can be used as general ports or Uplink ports and can be simply plugged into a server, a hub or a switch, using straight cable or crossover cable.
The TP-LINK TL-SF1008D 8-port 10/100M Fast Ethernet Switch provides you with a low-cost, easy-to-use, high-performance, seamless and standard upgrade to improve your old network to a 100Mbps network. It will boost your network performance up to full duplex data transfer. Its wire-speed switching that forwards packets can be as fast as the speed that your network delivers those packets to them.
TP-Link TL-SF1008D 8-Port 10/100Mbps Desktop Switch - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
1K entries
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
(50/60 Hz)
14 cm x 8.5 cm x 3.3 cm
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
1K entries
Status Indicators
Power, link/activity
8 x 100Base-TX RJ-45
External power adapter
(50/60 Hz)
FCC
14 cm
8.5 cm
3.3 cm
10 - 90%
Type: Fast Ethernet
Ports: 8
Managed: No
POE: No
Brand: TP LINK
