TP LINK 8-Port 10/100 MBps Desktop PoE Switch
Quicklinx: 7VSVWS00 Mfr#: TL-SF1008P
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: No
POE: PoE
£37.98 ex VAT
£45.57 inc VAT
The TL-SF1008P 8-port 10/100M Desktop PoE Switch provides the seamless network connection. It integrates 100Mbps Fast Ethernet and 10Mbps Ethernet network capabilities.
4 of the 8 auto-negotiation RJ45 ports (port-1 to port-4) of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af compliant Powered Devices (PDs). In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network where there are no power lines or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones, etc.
TL-SF1008P has the priority function which will help protect the system when the system power is overloaded.
TL-SF1008P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-link TL-SF1008P 8-port 10/100M Desktop PoE Switch is a great selection for expanding your home or office network.
TP-Link TL-SF1008P - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE) + 4 x 10/100
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
1K entries
Flow control, full duplex capability, PoE, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
17.1 cm x 9.8 cm x 2.7 cm
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
1K entries
Status Indicators
Port transmission speed, power, link/activity
4 x 100Base-TX RJ-45 , 4 x 100Base-TX RJ-45 PoE
External power adapter
FCC
17.1 cm
9.8 cm
2.7 cm
10 - 90%
7VSV C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
7VSV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
Type: Fast Ethernet
Ports: 8
Managed: No
POE: PoE
Brand: TP LINK
