TP LINK 8-Port 1 x WAN + 8 x LAN Cable/DSL Router
Quicklinx: 897VWS00 Mfr#: TL-R860
The TL-R860 multifunctional broadband router is especially designed for SOHO (Small Office/Home Office) to access the Internet. It features strong functions, high performance, and easy configuration router. The TL-R860 provides many management functions.
The TL-R860 router provides flexible access control, limiting staff or children to browse selected sites. The TL-R860 router is also a smart helper. It connects to the Internet automatically on demand and disconnects when idle to save on network costs. It's easy to configure.
TP-Link TL-R860 - router - desktop
Router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Network / Transport Protocol
TCP/IP, L2TP, ICMP/IP, PPPoE, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, IP address filtering, firmware upgradable, SNTP support, virtual server support
IEEE 802.3, IEEE 802.3u, IEEE 802.1x, UPnP
18.6 cm x 14.6 cm x 4.4 cm
Enclosure Type
Desktop
Wired
Data Transfer Rate
100 Mbps
Routing Protocol
Static IP routing
HTTP
IEEE 802.3, IEEE 802.3u, IEEE 802.1x, UPnP, FCC
Status Indicators
100M device connected, link/activity
LAN: 8 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
External power adapter
18.6 cm
14.6 cm
4.4 cm
10 - 90%
897V C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
897V C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.64
