As the flagship 2.5G products, the 5/8-Port desktop switches with 5/8x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices, and provide up to 25/40 Gbps of switching capacity. Auto-negotiation 3-speed (100Mb/1G/2.5G) connections sense the link speeds and intelligently adjust for compatibility and optimal performance for all your devices, including 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, 2.5G Wi-Fi 6 AP, 4K video, desktop, and more.
                Five 2.5 Gbps ports5x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices and provide up to 25 Gbps of switching capacity.
                Super-fast connectionsProvides super-fast connections to 2.5G NAS, 2.5G Server, gaming computer, 2.5G Wi-Fi 6 AP, 4K video, and more.
                Ideal for various scenariosBuilt for LAN parties, home entertainment, small and home offices, and instant transfer for workstations,
                Hassle-free cablingInstantly upgrade to 2.5 Gbps without the need to upgrade to Cat6 wiring, reducing wiring costs and hassle.
                Silent operationIndustry-leading fanless design ensures silent operation, ideal for any home or business.
                Plug and PlayAllows for easy deployment without the need for a technician.
                Metal casingDurable metal casing and desktop/wall-mounting design are well-suited for different environments.
- TP-Link TL-SG105-M2 - V1 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- 2.5 Gigabit Ethernet
- Ports
- 5 x 100/1000/2.5G
- Performance
- Switching capacity: 25 Gbps , Packet forwarding rate: 18.6 Mpps
- Capacity
- Packet buffer size: 1.5 MB
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 10000 bytes
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, metal housing, DSCP support
- IEEE 802.1p, IEEE 802.3x
- 20.9 cm x 12.6 cm x 2.6 cm
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Ports
- 5 x 100/1000/2.5G
- Performance
- Capacity
- 16K entries
- 10000 bytes
- Status Indicators
- Power, status
- 5 x 100/1000/2.5G RJ-45
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 1 A
- Plug and Play, FCC, RoHS
- 20.9 cm
- 12.6 cm
- 2.6 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
