As the flagship 2.5G products, the 5/8-Port desktop switches with 5/8x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices, and provide up to 25/40 Gbps of switching capacity. Auto-negotiation 3-speed (100Mb/1G/2.5G) connections sense the link speeds and intelligently adjust for compatibility and optimal performance for all your devices, including 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, 2.5G Wi-Fi 6 AP, 4K video, desktop, and more.
Five 2.5 Gbps ports
5x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices and provide up to 25 Gbps of switching capacity. -
Super-fast connections
Provides super-fast connections to 2.5G NAS, 2.5G Server, gaming computer, 2.5G Wi-Fi 6 AP, 4K video, and more. -
Ideal for various scenarios
Built for LAN parties, home entertainment, small and home offices, and instant transfer for workstations, -
Hassle-free cabling
Instantly upgrade to 2.5 Gbps without the need to upgrade to Cat6 wiring, reducing wiring costs and hassle. -
Silent operation
Industry-leading fanless design ensures silent operation, ideal for any home or business. -
Plug and Play
Allows for easy deployment without the need for a technician. -
Metal casing
Durable metal casing and desktop/wall-mounting design are well-suited for different environments.
 - TP-Link TL-SG105-M2 - V1 - switch - 5 ports - unmanaged
 - Switch - 5 ports - unmanaged
- Subtype
 - 2.5 Gigabit Ethernet
- Ports
 - 5 x 100/1000/2.5G
- Performance
 - Switching capacity: 25 Gbps , Packet forwarding rate: 18.6 Mpps
- Capacity
 - Packet buffer size: 1.5 MB
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 10000 bytes
 - Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, metal housing, DSCP support
 - IEEE 802.1p, IEEE 802.3x
 - 20.9 cm x 12.6 cm x 2.6 cm
- Enclosure Type
 - Desktop, wall-mountable
- Subtype
- Ports
 - 5 x 100/1000/2.5G
- Performance
- Capacity
 - 16K entries
 - 10000 bytes
- Status Indicators
 - Power, status
 - 5 x 100/1000/2.5G RJ-45
- Power Device
 - External power adapter
- Power Provided
 - DC 12 V - 1 A
 - Plug and Play, FCC, RoHS
 - 20.9 cm
 - 12.6 cm
 - 2.6 cm
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 95% (non-condensing)
