TP LINK 5-Port Multi-Gigabit Desktop Switch
Quicklinx: G6X3WS00 Mfr#: TL-SG105-M2
Type: 2.5 Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: No
10 In Stock
£48.80 ex VAT
£58.56 inc VAT
As the flagship 2.5G products, the 5/8-Port desktop switches with 5/8x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices, and provide up to 25/40 Gbps of switching capacity. Auto-negotiation 3-speed (100Mb/1G/2.5G) connections sense the link speeds and intelligently adjust for compatibility and optimal performance for all your devices, including 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, 2.5G Wi-Fi 6 AP, 4K video, desktop, and more.
  • Five 2.5 Gbps ports
    5x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices and provide up to 25 Gbps of switching capacity.
  • Super-fast connections
    Provides super-fast connections to 2.5G NAS, 2.5G Server, gaming computer, 2.5G Wi-Fi 6 AP, 4K video, and more.
  • Ideal for various scenarios
    Built for LAN parties, home entertainment, small and home offices, and instant transfer for workstations,
  • Hassle-free cabling
    Instantly upgrade to 2.5 Gbps without the need to upgrade to Cat6 wiring, reducing wiring costs and hassle.
  • Silent operation
    Industry-leading fanless design ensures silent operation, ideal for any home or business.
  • Plug and Play
    Allows for easy deployment without the need for a technician.
  • Metal casing
    Durable metal casing and desktop/wall-mounting design are well-suited for different environments.
TP-Link TL-SG105-M2 - V1 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Ports
5 x 100/1000/2.5G
Performance
Switching capacity: 25 Gbps , Packet forwarding rate: 18.6 Mpps
Packet buffer size: 1.5 MB
MAC Address Table Size
16K entries
Jumbo Frame Support
10000 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, metal housing, DSCP support
IEEE 802.1p, IEEE 802.3x
20.9 cm x 12.6 cm x 2.6 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Ports
5 x 100/1000/2.5G
Performance
16K entries
Jumbo Frame Support
10000 bytes
Status Indicators
Power, status
5 x 100/1000/2.5G RJ-45
External power adapter
Power Provided
DC 12 V - 1 A
Plug and Play, FCC, RoHS
20.9 cm
12.6 cm
2.6 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 5
Managed: No
POE: No
Brand: TP LINK
