TL-SG1005LP is a professional 5-port Gigabit switch with 4 PoE+ ports. The total 40 W PoE power budget for the four PoE ports opens up a wide range of applications, such as surveillance for offices, dormitories, and small businesses. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more. The interior components of TL-SG1005LP are protected by high-quality metal casing to ensure a long product life.
Dedicated 4-port PoE+ switch (40 W budget) for numerous applications
The total 40 W PoE power budget for the four PoE ports opens up a wide range of applications, such as surveillance for offices, dormitories, and small businesses. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more. -
Intelligent power management
When total power consumption exceeds 40 W, the intelligent power management will cut the lower priority port power. This ensures the high priority port's power supply and protects the device from power overload. It also automatically detects and provides the required power for your PoE devices while protecting your PoE and non-PoE equipment from being damaged. -
Qos for fluent online experience
Administrators can designate the priority of traffic based on QoS, for example, to ensure that voice and video applications remain clear and lag-free. -
IGMP snooping - traffic optimization for IPTV
IGMP Snooping optimizes multimedia traffic delivery, to ensure a better network experience especially for applications like IPTV. -
Durable metal casing
The interior components of TL-SG1005LP are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, TL-SG1005LP delivers switching performance you can depend on.
- TP-Link TL-SG1005LP - V1 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000 (4 PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 40 W
- Performance
- Packet forwarding rate: 7.44 Mpps , Switching capacity: 10 Gbps
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 16KB
- Routing Protocol
- IGMP
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, QoS, fanless, DSCP support
- IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- 9.98 cm x 9.8 cm x 2.5 cm
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 40 W
- Performance
- 2K entries
- 16KB
- Routing Protocol
- IGMP
- 5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W
- Power Device
- External power adapter
- Power Provided
- DC 53.5 V - 0.81 A
- 47.5 watt
- Plug and Play, FCC, RoHS
- 9.98 cm
- 9.8 cm
- 2.5 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
