The TL-SG1005D 5-port Gigabit Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network.
Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files and other applications that have to move large files across the network almost instantly.
With 5 10/100/1000Mbps ports, TL-SG1005D greatly expands your network capacity, enabling instant large files transferring.
Innovative energy-efficient technology saves power up to 70%
Supports IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode
Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput
10Gbps Switching Capacity
9K Jumbo frame improves performance of large data transfers
Auto-MDI/MDIX eliminates the need for crossover cables
Supports MAC address auto-learning and auto-aging
Auto-negotiation ports provide smart integration between 10Mbps, 100Mbps and 1000Mbps hardware
Fanless design ensures quiet operation
Desktop or wall-mounting design
Plug and Play design simplifies installation
- TP-Link TL-SG1005D 5-Port Gigabit Desktop Switch - switch - 5 ports
- Switch - 5 ports
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
- Power
- (50/60 Hz)
- 18.6 cm x 14.6 cm x 4.4 cm
- Switch - 5 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Status Indicators
- Power, link/activity
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- (50/60 Hz)
- FCC
- 18.6 cm
- 14.6 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.96 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
