Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
TP LINK 5-port Desktop Gigabit Switch
Quicklinx: 77S5WS00 Mfr#: TL-SG1005D
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 In Stock
£11.24 ex VAT
£13.48 inc VAT
The TL-SG1005D 5-port Gigabit Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network.
Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files and other applications that have to move large files across the network almost instantly.
With 5 10/100/1000Mbps ports, TL-SG1005D greatly expands your network capacity, enabling instant large files transferring.
Innovative energy-efficient technology saves power up to 70%
Supports IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode
Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput
10Gbps Switching Capacity
9K Jumbo frame improves performance of large data transfers
Auto-MDI/MDIX eliminates the need for crossover cables
Supports MAC address auto-learning and auto-aging
Auto-negotiation ports provide smart integration between 10Mbps, 100Mbps and 1000Mbps hardware
Fanless design ensures quiet operation
Desktop or wall-mounting design
Plug and Play design simplifies installation
TP-Link TL-SG1005D 5-Port Gigabit Desktop Switch - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
(50/60 Hz)
18.6 cm x 14.6 cm x 4.4 cm
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
(50/60 Hz)
FCC
18.6 cm
14.6 cm
4.4 cm
10 - 90%
Ports: 5
Managed: No
POE: No
Brand: TP LINK
Stock Status: Clearance
