TP LINK 32-bit Gigabit PCIe Adapter
Quicklinx: 77SHWS00 Mfr#: TG-3468
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
More than 50 In Stock
£9.30 ex VAT
£11.16 inc VAT
TG-3468 10/100/1000Mbps Gigabit PCIe Network Adapter is a highly integrated and cost-effective 32-bit Gigabit PCIe Ethernet Adapter which is fully compliant with IEEE 802.3, IEEE 802.3u and IEEE 802.3ab specifications.
The PCIe Gigabit Network Adapter TG-3468 is a high performance adapter designed for the high-speed PCI Express Bus Architecture. Designed to support 10/100/1000Mbps network speed Auto-Negotiation, 802.3x flow control and Wake-on-LAN technology. TG-3468 Gigabit PCIe Network Adapter is a highly integrated and cost-effective Gigabit Ethernet adapter which is a good selection to upgrade your network.
TP-Link TG-3468 - network adapter - PCIe - Gigabit Ethernet
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
Gigabit Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, CSMA/CD
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Network adapter
Plug-in card
PCI Express x1
PCIe 1.0a
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
TCP/IP, CSMA/CD
Status Indicators
Port duplex mode, link/activity
Flow control, auto-negotiation, WOL, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x1
FCC
Limited warranty - parts and labour - 2 years
10 - 90%
77SH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
77SH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
77SH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Protocol: Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: TP LINK
