TP LINK 300Mbps Wireless N USB VDSL2 Modem Router
Quicklinx: BJWQWS00 Mfr#: TD-W9970
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: IEEE 802.11n, Fast Ethernet, Ethernet, IEEE 802.11g + 1 more
Speed: [N/A]
Rackmount or External: Desktop
  • IEEE 802.11n
More than 50 In Stock
£29.41 ex VAT
£35.29 inc VAT
TP-LINK's 300 Mbps Wireless N USB VDSL2 modem router TD-W9970 is an incredibly robust all-in-one device allowing users to access high-speed Internet connection via VDSL/ADSL, 3G/4G modem or Ethernet WAN (EWAN) using its interchangeable LAN/WAN port and share it wirelessly at 300 Mbps wireless 802.11n speeds. With its multifunctional USB port, users can share printers, files & media across the local network or share files & media via the Internet. Moreover, it supports the Internet protocol IPv6 to future-proof your network.
TP-Link TD-W9970 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP
Firewall protection, DMZ port, NAT support, IGMP snooping, traffic shaping, print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, WMM support, QoS, DPD, virtual server support, FTP server, port triggering, DHCP relay, DNS relay, port grouping, Guest Zone support
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
19.5 cm x 13 cm x 3.6 cm
Microsoft Windows Vista / XP / 7 / 8 / 8.1
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1
WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x
Aerial
Aerial
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
ADSL splitter
1 x network cable , 1 x modem cable
19.5 cm
13 cm
3.6 cm
10 - 90% (non-condensing)
BJWQ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.63
Standards: Fast Ethernet
Standards: Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11b
Speed: [N/A]
Brand: TP LINK
