TP-LINK's 300 Mbps Wireless N USB VDSL2 modem router TD-W9970 is an incredibly robust all-in-one device allowing users to access high-speed Internet connection via VDSL/ADSL, 3G/4G modem or Ethernet WAN (EWAN) using its interchangeable LAN/WAN port and share it wirelessly at 300 Mbps wireless 802.11n speeds. With its multifunctional USB port, users can share printers, files & media across the local network or share files & media via the Internet. Moreover, it supports the Internet protocol IPv6 to future-proof your network.
- TP-Link TD-W9970 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2+, VDSL2
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP
- Firewall protection, DMZ port, NAT support, IGMP snooping, traffic shaping, print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, WMM support, QoS, DPD, virtual server support, FTP server, port triggering, DHCP relay, DNS relay, port grouping, Guest Zone support
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 19.5 cm x 13 cm x 3.6 cm
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8 / 8.1
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- ADSL2+, VDSL2
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1
- WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Included Accessories
- ADSL splitter
- Cables Included
- 1 x network cable , 1 x modem cable
- OS Required
- 19.5 cm
- 13 cm
- 3.6 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.01 |
