High Gain USB Adapter TL-WN822N is a 300Mbps wireless client, which allows you to connect a desktop or notebook computer to a wireless network and access high-speed Internet connection.
It is fully interoperable with IEEE 802.11n/b/g wireless devices, delivering fabulous N speed and reliable signal for online gaming, Internet calls or even the HD video streaming.
Dual 3dBi External Antennas
TL-WN822N features its dual 3dBi external antennas besides the exterior, which can be rotated and adjusted in different directions to fit various operation environments, brings performance enhancement than internal antenna under normal indoor usage.
One Button for Security Setup
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WN822N supports Quick Security Setup that allows users to simply press the "QSS" button on the device's exterior, instantly establishing a highly secured connection.
Not only is it faster than normal security setups but more convenient in that you don't need to remember any password!
Bundled CD for Easy Use
TL-WN822N comes with a CD with utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which is convenient for users, even for novice users.
Desktop-Style Design
Besides the fashionable and novelty exterior, the desktop-style design is beneficial for the signal reception in various application environments, guaranteeing the smooth and stable signal.
                Desktop-style design and long USB cableApart from its fashionable exterior, the TL-WN822N’s desktop-style design is truly beneficial for signal reception in various environments, providing smooth and stable signals. The TL-WN822N also provides a long USB cable, convenient for installation and flexible deployment.
                External antennasDual external antennas ensure easy alignment to achieve excellent signal.
                WPS buttonEasy wireless security encryption at a push of the WPS button.
                Easy setupUsing the optimized setup wizard will allow you to get online quickly and easily.
- TP-Link TL-WN822N - network adapter - USB
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 9 cm x 6.8 cm x 1.7 cm
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
- Network adapter
- Form Factor
- External
- USB
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM
- 300 Mbps
- Line Coding Format
- CCK, 64 QAM, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz
- Ad-Hoc Mode, WPS
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 3 dBi
- Connections
- 1 x USB - mini-USB Type A
- Cables Included
- 1 x USB extension cable (external) - 1.5 m
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 9 cm
- 6.8 cm
- 1.7 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
