TP LINK 300Mbps Wireless N USB Adapter
Quicklinx: 77RNWS00 Mfr#: TL-WN822N
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£11.55 ex VAT
£13.86 inc VAT
High Gain USB Adapter TL-WN822N is a 300Mbps wireless client, which allows you to connect a desktop or notebook computer to a wireless network and access high-speed Internet connection.
It is fully interoperable with IEEE 802.11n/b/g wireless devices, delivering fabulous N speed and reliable signal for online gaming, Internet calls or even the HD video streaming.
Dual 3dBi External Antennas
TL-WN822N features its dual 3dBi external antennas besides the exterior, which can be rotated and adjusted in different directions to fit various operation environments, brings performance enhancement than internal antenna under normal indoor usage.
One Button for Security Setup
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WN822N supports Quick Security Setup that allows users to simply press the "QSS" button on the device's exterior, instantly establishing a highly secured connection.
Not only is it faster than normal security setups but more convenient in that you don't need to remember any password!
Bundled CD for Easy Use
TL-WN822N comes with a CD with utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which is convenient for users, even for novice users.
Desktop-Style Design
Besides the fashionable and novelty exterior, the desktop-style design is beneficial for the signal reception in various application environments, guaranteeing the smooth and stable signal.
  • Desktop-style design and long USB cable
    Apart from its fashionable exterior, the TL-WN822N’s desktop-style design is truly beneficial for signal reception in various environments, providing smooth and stable signals. The TL-WN822N also provides a long USB cable, convenient for installation and flexible deployment.
  • External antennas
    Dual external antennas ensure easy alignment to achieve excellent signal.
  • WPS button
    Easy wireless security encryption at a push of the WPS button.
  • Easy setup
    Using the optimized setup wizard will allow you to get online quickly and easily.
TP-Link TL-WN822N - network adapter - USB
Network adapter
External
Interface (Bus) Type
USB
9 cm x 6.8 cm x 1.7 cm
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Network adapter
External
USB
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz
Ad-Hoc Mode, WPS
Aerial
Antenna
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
3 dBi
1 x USB - mini-USB Type A
1 x USB extension cable (external) - 1.5 m
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
9 cm
6.8 cm
1.7 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: TP LINK
