TP LINK 300Mbps Wireless-N Router with 4Port Switch (10/100) and tw
Quicklinx: 7MGNWS00 Mfr#: TL-WR841ND
  • IEEE 802.11n (draft 2.0)
The TL-WR841ND Wireless N Router is a combined wired/wireless network connection device designed specifically for small business, office, and home office networking requirements. It complies with the IEEE 802.11n (Draft 2.0)standard with wireless transmission speeds of up to 300M. The router adopts 2 2 MIMO technology and has two external antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. It also works well with other 11g and 11n protocol wireless products.
The TL-WR841ND provides multiple security measures; supporting SSID broadcast control, MAC address access control, WEP encryption, WPA/WPA2, and WPA-PSK/WPA2-PSK authentication. At the same time QSS( Quick Secure Setup) complies with WPS allowing for worry-free wireless security configuration. These combined security features will guard against intruders using stronger, safer protection.
The TL-WR841ND allows companies, offices, and homes to share one Internet connection with more computers. Apart from this product is simple setup and more common broadband router functions, it also supports priority of service where applications using a lot of bandwidth that are sensitive to interruptions such as voice and video are given priority in order to assure quality This is a fashionable product with superior performance and should be your first choice when setting up a network.
TP-Link TL-WR841ND 300Mbps Wireless N Router with Detachable Antennas - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Network / Transport Protocol
TCP/IP, ICMP/IP, PPPoE, DHCP, DNS
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, MIMO technology, virtual server support, DHCP server
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0), UPnP
20 cm x 14 cm x 2.8 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0), UPnP, FCC
Status Indicators
Power, system, link/activity
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
3 dBi
External power adapter
Software Included
Drivers & Utilities
20 cm
14 cm
2.8 cm
10 - 90%
