The TL-WR802N is designed for use with tablets, smart phones, handheld game consoles and other portable electronic wireless devices. The devices, which can be powered by an external power adapter or USB connection to a computer, can conveniently connect to the Internet and share the connection around an average sized room at 300Mbps. The device's tiny size makes it ideal for use on the road and is powerful enough to satisfy almost any basic wireless application requirement.
The TL-WR802N is the perfect travel companion for anyone who needs fast, easy Internet access on the go. Portable and compact design easily fits into a pocket or the palm of your hand. Simply plug a hotel room's Ethernet cable into the port provided and enter a default password to instantly create a wireless hotspot in the room. It can be powered by an external power adapter or via a USB connection to a computer. When traveling, users can plug the TL-WR802N into computer's USB port and share Wi-Fi connection with family and friends.
What is the TL-WR802N
The TL-WR802N is designed for use with tablets, smart phones, handheld game consoles and other portable electronic wireless devices. The devices, which can be powered by an external power adapter or USB connection to a computer, can conveniently connect to the Internet and share the connection around an average sized room at 300Mbps. The device's tiny size makes it ideal for use on the road and is powerful enough to satisfy almost any basic wireless application requirement. -
Portable and compact - ideal for home and travel use
The TL-WR802N is the perfect travel companion for anyone who needs fast, easy Internet access on the go. Portable and compact design easily fits into a pocket or the palm of your hand. Simply plug a hotel room's Ethernet cable into the port provided and enter a default password to instantly create a wireless hotspot in the room. -
Flexible power supply - easy to take on the road
TL-WR802N can be powered by an external power adapter or via a USB connection to a computer. When traveling, users can plug the TL-WR802N into computer's USB port and share Wi-Fi connection with family and friends. -
Multiple operation modes
TL-WR802N supports Router (default), Repeater, Client, AP and WISP modes to enable various wireless applications to give users a more dynamic and comprehensive wireless networking experience.
- TP-Link TL-WR802N - wireless router - Wi-Fi - desktop
- Wireless router
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, IPSec
- Firewall protection, routing, repeating mode, SPI, DoS attack prevention, manageable, Access Point operational mode, WISP mode, WMM support, wireless bridge mode, reset button, Wireless Client Mode, IP-MAC binding
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 5.7 cm x 5.7 cm x 1.8 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7
- Wireless router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- PPTP, L2TP, IPSec
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
- WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x USB cable , 1 x network cable
- OS Required
- 5.7 cm
- 5.7 cm
- 1.8 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
