TP LINK 300Mbps Wireless N Cable Router 4 Port Switch
Quicklinx: 77RJWS00 Mfr#: TL-WR841N
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11n (draft 2.0), IEEE 802.11b, Ethernet, IEEE 802.11g + 1 more
Speed: 300Mbps
Rackmount or External: External
  • IEEE 802.11n (draft 2.0)
43 In Stock
£16.66 ex VAT
£19.99 inc VAT
300Mbps Wireless N Router TL-WR841N is a combined wired/wireless network connection device designed specifically for small business and home office networking requirements.
With 2T2R MIMO Technology, TL-WR841N creates an exceptional and advanced wireless performance, making it ideal for streaming HD video, making VoIP and online gaming.
Also, Quick Setup Security (QSS) button on the sleek and fashionable exterior ensures WPA2 encryptions, preventing the network from outside intrusions.
Wireless N Speed & Range
Complying with the IEEE 802.11n standard, TL-WR841N can establish a wireless network and get up to 15X the speed and 5X the range of conventional 11g products. Also, with transmission rates up to 300Mbps.
It shows more excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building.
Above all, you could easily pick up the wireless network during long-distance connection where legacy 11g products may not! Which also means, the router has the speed to work smoothly with almost any bandwidth intensive application including VoIP, HD streaming, or online gaming, without the lag.
CCA Technology-Stable Wireless Signals
Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance.
WPA / WPA2 Encryptions - Advanced Security
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside threats.
TL-WR841N provides WPA/WPA2 encryptions (Both Personal and Enterprises) that are created by the WI-FI Alliance industry group, promoting interpretabilities and security for WLAN.
QSS Button - Quick Setup Security
Compatible with WI-FI Protected Setup™ (WPS), TL-WR841N features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the "QSS" button automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions.
Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
IP QoS-Control Bandwidth Reasonably
Among the wireless network, indiscriminate Internet surfing and bandwidth-guzzling downloads by internal users often leave home or small office with insufficient bandwidth.
TL-WR841N supports IP QoS function, allowing optimum utilization of bandwidth and offers bandwidth control over congestion, preventing the bandwidth abuse.
In this way, the users of a small network receive committed and specific bandwidth, preventing non-critical applications from degrading network performance.
Easy Setup
The device comes with a CD with an Easy Setup Assistant that leads you through the setup process step-by-step, and even helps with wireless network settings and security configurations, which is convenient to the users, especially for novice users.
  • Better wireless performance
    This router shows excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection! Which also means, the router has the speed to work smoothly with almost any bandwidth-intensive application including VoIP, streaming of high-quality content or online gaming, without the lag.
  • Connection encryption
    The encryption ensures your wireless connection is safe from intruders.
  • WPS button
    Instantly setup Wi-Fi connections simply by pressing the WPS button.
  • IP QoS
    IP-based bandwidth control allows administrators to determine how much bandwidth is allotted to each PC.
  • Easy setup
    The optimized setup wizard will allow you to get online quickly and easily.
TP-LINK TL-WR841N Wireless N 300Mbps Router - wireless router - 802.11b/g/n (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPPoE
Routing Protocol
Static IP routing
Firewall protection, DMZ port, dynamic IP address assignment , auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, MIMO technology, virtual server support, DHCP server
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0), UPnP
20 cm x 14 cm x 2.8 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPPoE
Routing Protocol
Static IP routing
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
3 dBi
Power adapter - external
20 cm
14 cm
2.8 cm
Software Included
Drivers & Utilities
10 - 90%
77RJ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
77RJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.94
77RJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.76
Standards: IEEE 802.11b
Standards: Ethernet
Standards: IEEE 802.11g
Standards: Fast Ethernet
Speed: 300Mbps
Brand: TP LINK
