The TP-LINK Wireless N ADSL2+ Modem Router (TD-W8960N) is an all-in-one device that combines the functions of a high speed DSL modem, a 4-port 10/100Mbps NAT router and a wireless N access point. The TD-W8960N is designed to give you a one-stop solution to acquiring and sharing high speed Internet access over a wired/wireless network.
Supporting the latest ADSL standards to provide higher performance and longer reach from your Internet Service Provider (ISP) Digital Subscriber Line Access Multiplexer (DSLAM), the TD-W8960N brings with it much higher speed than a dial-up connection without tying up the phone line.
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 15x the speed and 5x the range of conventional 11g products. Now you can share your high-speed DSL Internet connection, photos, music, videos, printers, Network Attached Storage (NAS) and even the bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard! The TD-W8960N supports QoS to enable smooth VoIP/IPTV streaming and lag-free online gaming.
Featuring IPSec VPN function, TD-W8960N allows off-site or traveling users to securely access the company's central network through the Internet. VPN is short for Virtual Private Network, which creats encrypted tunnels through the Internet between the company's private network and the remote or traveling users off-site. These tunnels are using virtual connections instead of the dedicated, real-world connection such as leased line. Featuring IPSec VPN function, the TP-LINK TD-W8960N is no longer just a wireless ADSL modem router, it can work as a VPN gateway, which supports up to 10 IPSec VPN tunnels simultaneously. As such, users can allow for complete data privacy for the access and exchange of user's most sensitive data from home to corporate network or between remote branch offices safely.
3-in-1 device
The TP-LINK Wireless N ADSL2+ Modem Router (TD-W8960N) is an all-in-one device that combines the functions of a high speed DSL modem, a 4-port 10/100Mbps NAT router and a wireless N access point. The TD-W8960N is designed to give you a one-stop solution to acquiring and sharing high speed Internet access over a wired/wireless network. -
Access high-speed Internet
Supporting the latest ADSL standards to provide higher performance and longer reach from your Internet Service Provider (ISP) Digital Subscriber Line Access Multiplexer (DSLAM), the TD-W8960N brings with it much higher speed than a dial-up connection without tying up the phone line. -
Sharing Internet through wireless
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 15x the speed and 5x the range of conventional 11g products. Now you can share your high-speed DSL Internet connection, photos, music, videos, printers, Network Attached Storage (NAS) and even the bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard! The TD-W8960N supports QoS to enable smooth VoIP/IPTV streaming and lag-free online gaming. -
Quick Secure Setup (QSS)
QSS or Quick Security Setup (QSS) is a handy feature that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless router or entering the PIN Code in the net card, it automatically establishes a WPA2 secure connection, instantly protecting your network. With just one click of the QSS button, it automatically establishes a WPA2 secure connection for solid security in under a minute. -
Keep data secure
- TP-Link TD-W8960N - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Permanent virtual circuits (PVC): up to 8 , IPSec VPN tunnels: up to 10
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS, DDNS
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP
- Firewall protection, DMZ port, NAT support, VLAN support, IGMP snooping, traffic shaping, packet filtering, MAC address filtering, VPN passthrough, URL filtering, parental control, IP address filtering, firmware upgradable, MIMO technology, IPSec VPN, ACL support, QoS, virtual server support, WPS, IPSec passthrough, port forwarding, bandwidth control, SPIF, DNS relay, application filtering, DoS, SYN Flooding, Ping of Death
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 18.16 cm x 12.57 cm x 3.62 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000 / NT, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, SSL, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Line Properties
- Framing Format
- ANSI T1.413i2
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
- Max Transfer Rate
- 24 Mbps
- WAN: 1 x ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 3 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Included Accessories
- ADSL splitter
- Cables Included
- 1 x phone cable , 1 x network cable
- Software Included
- Easy Setup Assistant
- OS Required
- 18.16 cm
- 12.57 cm
- 3.62 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
