TP LINK 300Mbps Mini Wireless N USB Adapter
Quicklinx: 83H9WS00 Mfr#: TL-WN823N
Wired / Wireless: Wireless
Protocol: IEEE 802.11n, IEEE 802.11g, IEEE 802.11b
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
More than 50 In Stock
£8.25 ex VAT
£9.90 inc VAT
TP-LINK's 300Mbps Mini Wireless N USB Adapter TL-WN823N is designed to connect your laptop or desktop to a wireless network and enjoy high speed wireless performance. The fingertip design makes the adapter convenient and easy to carry around. What's more, the TL-WN823N features SoftAP Mode, one-button security setup, easy-to-use configuration software, making it a great choice for enjoying fast wireless network.
300Mbps Wireless N Speed - Extend Wireless Coverage
With wireless speeds of up to 300Mbps and advanced MIMO technology, the TL-WN823N provides you with a fast, reliable wireless connection for lag-free online gaming and video streaming. Better still, TL-WN823N achieves the best performance with wireless N devices, but also works seamlessly with existing IEEE 802.11b/g networks.
SoftAP Mode - Easy Wireless Internet Sharing
SoftAP Mode enables this tiny adapter to work as a virtual wireless Access Point. Once applied, this mode allows users to easily turn their existing wired connections to a laptop or PC into wireless and share it with other Wi-Fi enabled devices like laptops, smartphones or tablets.
One Button Security Setup
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WN823N features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the WPS button to automatically establish a WPA2 secure connection, more secure than WEP encryptions. Not only is this faster than normal security setups but more convenient in that users needn't remember a password!
Easy to Use
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just few minutes. Its simple and user friendly interface makes TL-WN823N so convenient that even novice users can get started quickly and establish their connections effortlessly.
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Compatibility: PC
Brand: TP LINK
