The TL-SG1428PE is fully compatible with PoE devices, such as IP cameras, access points, and IP phones. It also works with non-PoE wired devices to provide gigabit connections, such as PCs, printers, and IPTV.
- TP-Link TL-SG1428PE - switch - 28 ports - smart - rack-mountable
- Switch - 28 ports - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 2 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 250 W
- Performance
- Switching capacity: 56 Gbps ¦ Forwarding performance: 41.7 Mpps
- Capacity
- Packet buffer size: 4.1 Mbit
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, Cable Diagnostics Function, loop prevention, security lock slot (cable lock sold separately), DSCP support, 2 fans, Storm Control, Static Link Aggregation, DSCP prioritisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 801.1p, IEEE 802.3at
- Power
- AC 100 - 240 V (50/60 Hz)
- 44 cm x 22 cm x 4.4 cm
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 250 W
- Performance
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- 24 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W , 2 x 10/100/1000 Base-T RJ-45
- Expansion Slots
- 2 (total) / 2 (free) x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 304.7 watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- FCC, RoHS
- 44 cm
- 22 cm
- 4.4 cm
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
