TP LINK 28-Port Gigabit Easy Smart Switch With 24-Port PoE+
Quicklinx: FZ6LWS00 Mfr#: TL-SG1428PE
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: 36
Managed: Yes
POE: PoE+
11 In Stock
£160.84 ex VAT
£193.00 inc VAT
The TL-SG1428PE is fully compatible with PoE devices, such as IP cameras, access points, and IP phones. It also works with non-PoE wired devices to provide gigabit connections, such as PCs, printers, and IPTV.
TP-Link TL-SG1428PE - switch - 28 ports - smart - rack-mountable
Switch - 28 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 56 Gbps , Forwarding performance: 41.7 Mpps
Packet buffer size: 4.1 Mbit
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, Cable Diagnostics Function, loop prevention, security lock slot (cable lock sold separately), DSCP support, 2 fans, Storm Control, Static Link Aggregation, DSCP prioritisation
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 801.1p, IEEE 802.3at
AC 100 - 240 V (50/60 Hz)
44 cm x 22 cm x 4.4 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
250 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
24 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W , 2 x 10/100/1000 Base-T RJ-45
Expansion Slots
2 (total) / 2 (free) x SFP (mini-GBIC)
Internal power supply
304.7 Watt
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
44 cm
22 cm
4.4 cm
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 28
Managed: Yes
POE: PoE+
Brand: TP LINK
