TP LINK 24-port Gigabit Switch
Quicklinx: 77S8WS00 Mfr#: TL-SG1024
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 In Stock
£76.16 ex VAT
£91.39 inc VAT
The TL-SG1024 is specially designed for Ethernet (10Mbps), Fast Ethernet (100Mbps) and Gigabit Ethernet (1000Mbps) with seamless link. Each port supports up to 2000Mbps throughput in full duplex mode. It is the perfect choice to improve the performance of offices and workgroup networks.
TP-Link TL-SG1024 - switch - 24 ports - rack-mountable
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
24 x 1000Base-T RJ-45
44 cm
18 cm
4.4 cm
10 - 90%
77S8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
77S8 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
Ports: 24
Managed: No
POE: No
Brand: TP LINK
