The TL-SG1024 is specially designed for Ethernet (10Mbps), Fast Ethernet (100Mbps) and Gigabit Ethernet (1000Mbps) with seamless link. Each port supports up to 2000Mbps throughput in full duplex mode. It is the perfect choice to improve the performance of offices and workgroup networks.
 - TP-Link TL-SG1024 - switch - 24 ports - rack-mountable
 - Switch - 24 ports
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000
 - Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
- Power
 - AC 120/230 V (50/60 Hz)
 - 44 cm x 18 cm x 4.4 cm
 - Switch - 24 ports
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000
- Status Indicators
 - Power, 100M device connected, 1000M device connected, link/activity
 - 24 x 1000Base-T RJ-45
- Voltage Required
 - 44 cm
 - 18 cm
 - 4.4 cm
 - 0 °C
 - 40 °C
 - 10 - 90%
                        C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
                        C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
