TP LINK 24 Port Gigabit Smart PoE Switch plus 4 Combo SFP Slots
Quicklinx: 99GGWS00 Mfr#: TL-SG2424P
The TL-SG2424P provides 24 10/100/1000 Mbps ports that support 802.3at/af-compliant PoE, with a total PoE power supply up to 180 W, powerful and flexible enough for users to deploy wireless access points or IP-based network surveillance cameras. The switch also comes equipped with 4 combo SFP slots, expanding your network flexibly. In addition, it provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features. With all these advanced features, the Gigabit Smart PoE switch is an ideal choice for small and medium business networking.
TL-SG2424P has useful security features. The storm control feature protects against broadcast, multicast and unknown unicast storm. Quality of Service provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK Gigabit Smart PoE switch TL-SG2424P provides you the ideal access-edge solution.
  • IEEE 802.3at/af-compliant Power over Ethernet
    The TL-SG2424P supports 24 ports of IEEE 802.3at/af-compliant PoE and has a total power supply of 180 W to power any 802.3at or 802.3af compliant power device. It's an efficient and cost-effective choice to work with wireless access points, surveillance cameras, IP phones and other PoE supported devices, while getting rid of cables or power lines running around. Compact and flexible, the TL-SG2424P is ideal to flexibly use PoE to deploy wireless access points or IP-based network surveillance cameras for projects or small business networks.
  • Advanced QoS features
    To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including port priority, 802.1P priority and DSCP priority, to ensure that voice and video are always clear, smooth and jitter free.
  • Abundant Layer 2 features
    For more application of layer 2 switches, TL-SG2424P provides comprehensive layer 2 features, including 802.1Q tag VLAN, port isolation, port mirroring, STP/RSTP/MSTP, link aggregation group and 802.3x flow control function. Any more, the switch provides advanced features for network maintenance such as loop back detection, cable diagnostics and IGMP snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
  • Enterprise level management features
    TL-SG2424P is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or industry-standard Command Line Interface (CLI), SNMP and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
TP-Link TL-SG2424P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x combo SFP
Power Over Ethernet (PoE)
PoE+
Performance
Backplane speed: 48 Gbps , Forwarding performance: 35.7 Mpps
Active VLANs: 512
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Link Aggregation Control Protocol (LACP), Port Security, Strict Priority Queuing (SPQ), loop prevention, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
44 cm x 33 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 7, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista, Windows 8
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
Active VLANs: 512
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0, SSL 2.0
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Power, 100M device connected, system, 1000M device connected, PoE
24 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-T SFP
Internal power supply
Power Provided
180 Watt
Rubber feet
Rack Mounting Kit
Included
RoHS, FCC Part 15 A
Software Included
Drivers & Utilities
44 cm
33 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
99GG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
99GG C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
