TP LINK 24-port Gigabit Desk/Rackmount
Quicklinx: 77S7WS00 Mfr#: TL-SG1024D
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: No
POE: [N/A]
Hurry, only 1 left in stock!
£76.74 ex VAT
£92.08 inc VAT
The TL-SG1024D Gigabit Ethernet switch provides you with a high-performance, easy-to-use, seamless and standard upgrade to improve your network to 1000 Mbps network. All 24 ports support auto MDI / MDIX, no need to worry about the cable type, simply Plug and Play. Moreover, with the advanced energy-efficient technology, the TL-SG1024D can save a big amount of power consumption, making it an eco-friendly solution for your business network.
  • TP-LINK green technology
    This Gigabit switch features the advanced energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status to limit the carbon footprint of your network.
  • High performance
    All 24 ports are Gigabit RJ-45 ports which can provide large file transferring and also be compatible with 10 Mbps and 100 Mbps Ethernet devices. Featuring non-blocking switching architecture, TL-SG1024D forwards and filters packets at full wire speed for maximum throughput. With Jumbo frame, the performance of large files transfers is improved significantly. The TL-SG1024D is a perfect choice to update your network to Gigabit while protecting your previous investment properly.
  • Easy to use
    The auto features of this Gigabit switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI / MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SG1024D - switch - 24 ports - rack-mountable
Switch - 24 ports
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Switching capacity: 48 Gbps , Forwarding performance: 35.7 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 24 ports
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
10KB
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
24 x 1000Base-T RJ-45
External power adapter
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
44 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
77S7 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
77S7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.92
77S7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.58
Ports: 24
Managed: No
POE: [N/A]
Brand: TP LINK
