TP LINK 24-Port 10/100 Rackmount Unamanged Switch
Quicklinx: 896JWS00 Mfr#: TL-SF1024D
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£37.86 ex VAT
£45.43 inc VAT
The TL-SF1024D Fast Ethernet switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network. All 24 ports support auto MDI/MDIX, no need to worry about the cable type, simply Plug and Play. Moreover, with the innovative energy-efficient technology, the TL-SF1024D can save up to 75% of the power consumption and 80% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
  • High performance
    The rack-mount size metal case design combined with a safety certified internal power supply make the switch the most robust product which is very cost-effective for a less than 24 user environment. Featuring non-blocking switching architecture, TL-SF1024D forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for full duplex mode and backpressure for half duplex mode alleviate the traffic congestion and make TL-SF1024D work reliably.
  • TP-Link green technology
    The TL-SF1024D Fast Ethernet switch features energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
  • Easy to use
    The auto features of this Fast Ethernet switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SF1024D - switch - 24 ports
Switch - 24 ports
Ports
24 x 10/100
Performance
Switching capacity: 4.8 Gbps
MAC Address Table Size
8000 entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
29.4 cm x 18 cm x 4.4 cm
Switch - 24 ports
Enclosure Type
Desktop
Ports
24 x 10/100
Performance
8000 entries
Status Indicators
Power, link/activity
24 x 100Base-TX RJ-45
Rack Mounting Kit
Included
Plug and Play, FCC
29.4 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
896J C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
896J C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.64
Type: Fast Ethernet
Ports: 24
Managed: No
POE: No
Brand: TP LINK
