The TL-SF1024D Fast Ethernet switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network. All 24 ports support auto MDI/MDIX, no need to worry about the cable type, simply Plug and Play. Moreover, with the innovative energy-efficient technology, the TL-SF1024D can save up to 75% of the power consumption and 80% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
High performance
The rack-mount size metal case design combined with a safety certified internal power supply make the switch the most robust product which is very cost-effective for a less than 24 user environment. Featuring non-blocking switching architecture, TL-SF1024D forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for full duplex mode and backpressure for half duplex mode alleviate the traffic congestion and make TL-SF1024D work reliably. -
TP-Link green technology
The TL-SF1024D Fast Ethernet switch features energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. -
Easy to use
The auto features of this Fast Ethernet switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
 - TP-Link TL-SF1024D - switch - 24 ports
 - Switch - 24 ports
- Ports
 - 24 x 10/100
- Performance
 - Switching capacity: 4.8 Gbps
- MAC Address Table Size
 - 8000 entries
 - Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, fanless
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
 - AC 120/230 V (50/60 Hz)
 - 29.4 cm x 18 cm x 4.4 cm
 - Switch - 24 ports
- Enclosure Type
 - Desktop
- Ports
 - 24 x 10/100
- Performance
 - 8000 entries
- Status Indicators
 - Power, link/activity
 - 24 x 100Base-TX RJ-45
- Voltage Required
- Rack Mounting Kit
 - Included
 - Plug and Play, FCC
 - 29.4 cm
 - 18 cm
 - 4.4 cm
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 90% (non-condensing)
                        C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
                        C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
