TP LINK 20000mAh Power Bank
Quicklinx: FT8WWS00 Mfr#: TL-PB20000
This high capacity charger has 2 high-speed charging ports which provide up to 2.1A adaptive power output. Powered by TP-Link Smart Charging technology, these output ports can intelligently recognize different products and are designed to be capable of delivering appropriate power for devices with large and tiny battery respectively.
Li-Polymer battery is thin and lightweight while it also improves safety, leading to its wide applications in premium digital devices. Compared to those using Li-ion battery, this power bank looks much sleeker and thinner. It is a portable charger that perfectly fits in your hand while working with your phone.
Housed in a portable design, TL-PB20000 is a high capacity 20000mAh power bank compatible with most of your digital devices. With full capacity, it can hold enough juice to fully charge your device multiple times.
Supporting 5V/2.1A recharging speed, TL-PB20000 can quickly recover from empty to full capacity, saving much time as models supporting 5V/1A do.
  • Dual smart fast charging ports provide flexible power for different devices
  • Choose a power bank with superior li-polymer battery
  • Power your digital life on the move
  • Turbo recharging speed
  • Pass through charging
    You can charge the power bank and your devices simultaneously.
  • Universal compatibility
    It works great for smart devices running iOS, Android, Windows and most other USB-charged devices.
  • Travel ready, good for flight
    It's perfect for travel to carry a sufficient back-up power with slimline design.
  • Short circuit
    Short circuit protection: in case of short circuit by charging equipment or USB output port, providing microsecond level feedback protection.
  • Over-voltage
    Over-voltage protection: adapter problem, eg. adapter voltage is too high.
  • Over-current
    Over-current protection: abnormal charging device.
  • Over-charging
    Over-charging protection: during the charging process of mobile power, ensure the safety of mobile power.
  • Over-discharging
    Over-discharging protection: ensure the safety and performance of the cell and extend the life of mobile power supply.
  • Over-heating
    Over-heating protection: prevent product temperature from being too high to protect equipment safety.
TP-Link TL-PB20000 power bank - Li-pol - USB
Power bank
Camera, phone, tablet, headphones, portable game console
Output Connector Type
Total 2: USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Max Electric Current
2.1 A
Lithium polymer - 20000 mAh
Cables
Micro-USB cable
Power bank
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2.1 A
Smart Charge Technology, charging level indication, battery status button, pass-through charging
Lithium polymer
20000 mAh
Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
Micro-USB cable
