TP LINK 2.4GHz High Power Wireless Outdoor Access Point
Quicklinx: 8BMHWS00 Mfr#: TL-WA5210G
The TL-WA5210G 2.4 GHz High Power Wireless Outdoor CPE is dedicated to WISP CPE solution and long distance wireless network solutions. It integrates the functions of a Wireless Access Point, WISP Client, high gain antenna and weatherproof enclosure. It features 12 dBi high gain antenna, high output power and high RX sensitivity can significantly extend the transmission range to deliver a more stable wireless connection. Complies with IEEE 802.11 b/g, TL-WA5210G creates an wireless network up to 54 Mbps, making it great for Internet surfing and files exchange.
  • Weatherproof design, durable outdoor solution
    The TL-WA5210G is designed to work in harsh outdoor environment. Built with outdoor weatherproof enclosure and high durable of temperature hardware inside, the AP could work in some place with extreme bad weather conditions. Besides, the built-in 4000 V lightning and 15 KV ESD protection design would also help you to prevent storm/lightning surges and ensures reliable operation.
  • High power and receive sensitivity
    Just like a high-volume speaker to make your sound (wireless signal) travel further, the device features high power for higher speeds at further range for long distance applications giving your network the flexibility to go further. Signal degradation when traveling long distances is mitigated using high RX sensitivity meaning that you can get higher speed at further distances, just like a high-sensitivity headset, allowing the AP to detect and receive the weakest signals. These two aspects working together, ensure the signals can go further and bring higher speeds at the same distance than normal ones.
  • Long distance outdoor, break the limitation of Wi-Fi
    The TL-WA5210G features 12 dBi dual-polarized antennas which is the key feature to build long distance Wi-Fi connection. With software ACK timeout adjustable by setting the distance between two APs, it allows you to adjust the timeout value up to 15 km for outdoor long distance operation, or even 52 km with higher gain antenna support.
  • Passive PoE supported for more flexible deployment
    The TL-WA5210G is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP may be located even up to 200 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
TP-Link TL-WA5210G - radio access point - Wi-Fi
Radio access point
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
PoE injector
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows Vista / XP / 7, Microsoft Windows 2000 / NT
Power Over Ethernet (PoE) Supported
PoE
26.5 cm x 12 cm x 8.3 cm
Radio access point
26.5 cm
12 cm
8.3 cm
External
Wireless
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
Max Range Open Space
15 km
WISP mode, weatherproof
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Aerial
Directivity
Directional
Gain Level
12 dBi
PoE injector
FCC, RoHS
PoE
External power adapter
Software Included
Drivers & Utilities
-30 °C
70 °C
10 - 70%
8BMH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
8BMH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.71
8BMH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
