The TL-SG1218MP is fully compatible with PoE devices, such as IP cameras, access points, and IP phones. It also works with non-PoE wired devices to provide gigabit connections, such as PCs, printers, and IPTV.
- TP-Link JetStream TL-SG1218MP - V1 - switch - 18 ports - rack-mountable
- Switch - 18 ports
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 250 W
- Performance
- Switching capacity: 36 Gbps , Packet forwarding rate: 26.78 Mbps
- Capacity
- Packet buffer size: 4.1 Mbit
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 10KB
- Flow control, QoS, security lock slot (cable lock sold separately), DSCP support, 2 fans, Intelligent Power Management
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 18 cm x 4.4 cm
- Switch - 18 ports
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 250 W
- Performance
- Capacity
- 8K entries
- 10KB
- 16 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T / 1000Base-X RJ-45/SFP
- Power Device
- Internal power supply
- Voltage Required
- 286.64 watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- Plug and Play, FCC, RoHS
- 44 cm
- 18 cm
- 4.4 cm
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
