TP LINK 18-Port Gigabit Rackmount Switch With 16 PoE+
Quicklinx: FZ6NWS00 Mfr#: TL-SG1218MP
Type: Gigabit Ethernet
Ports: 18
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
More than 50 In Stock
£136.39 ex VAT
£163.66 inc VAT
The TL-SG1218MP is fully compatible with PoE devices, such as IP cameras, access points, and IP phones. It also works with non-PoE wired devices to provide gigabit connections, such as PCs, printers, and IPTV.
TP-Link JetStream TL-SG1218MP - V1 - switch - 18 ports - rack-mountable
Switch - 18 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 36 Gbps , Packet forwarding rate: 26.78 Mbps
Packet buffer size: 4.1 Mbit
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, QoS, security lock slot (cable lock sold separately), DSCP support, 2 fans, Intelligent Power Management
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
44 cm x 18 cm x 4.4 cm
Switch - 18 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
250 W
Performance
8K entries
Jumbo Frame Support
10KB
16 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T / 1000Base-X RJ-45/SFP
Internal power supply
286.64 watt
Rubber feet
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
44 cm
18 cm
4.4 cm
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 18
Managed: No
POE: PoE+
Brand: TP LINK
