TP LINK 16-Port 10/100Mbps PoE+ Switch
Quicklinx: FNDBWS00 Mfr#: TL-SL1218MP
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
More than 50 In Stock
£116.79 ex VAT
£140.14 inc VAT
TP-Link's new TL-SL1218MP PoE switch with all 16 ports supporting the PoE+ standard provides a simple way to expand the wired network while transferring power over the same Ethernet cable at the same time. With a total power budget of 192W, up to 30W per port, TL-SL1218MP can power more high-powered devices such as Access Points, IP Cameras, IP Phones and so on. Moreover, with innovative Extend Mode, devices can get PoE power supply and data transmission from 250m's distance. Priority mode ensures high priority for Port 1-8, which guarantees the quality of sensitive applications.
TP-Link TL-SL1218MP - switch - 16 ports - unmanaged - rack-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
PoE Budget
192 W
Performance
Switching capacity: 7.2 Gbps , Packet forwarding rate: 5.36 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
PoE Budget
192 W
Performance
8K entries
Jumbo Frame Support
10KB
Status Indicators
Power, 100M device connected, link/activity
16 x 100Base-TX RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
217.22 Watt
Rack Mounting Kit
Included
Plug and Play, FCC Class A certified, EN 60950, EN55022, EN55024, FCC Part 15
44 cm
18 cm
4.4 cm
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 16
Managed: No
POE: PoE+
Brand: TP LINK
