TP LINK 16-port 10/100M Swit 16 RackMo
Quicklinx: 78VHWS00 Mfr#: TL-SF1016
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 100Mbps
Managed: No
POE: No
Hurry, only 2 left in stock!
£32.46 ex VAT
£38.95 inc VAT
The TL-SF1016 16-port 10/100Mbps Ethernet Switch is designed for SOHO (Small Office/Home Office) or workgroup users. The rack-mount size metal case design combined with a safety certified internal power supply make the Switch the most robust product which is very cost-effective for a less than 16 user environment. The plug-and-play and auto-negotiation capabilities allow the Switch to auto-detect its link partner (Ethernet adapter, for example) with the best speed. Each port provides full bandwidth (Maximum with 200Mbps in full duplex mode) without a traditional hub's collision phenomenon downgrading the performance. All ports can be the uplink (cascade) port, which is provided to link to another Switch for more ports expansion. Easy read LED indicators are supported for cable installation and normal operation diagnostics. The Switch can be used on desktop and rack-mount.
  • Ease of use
    The auto features of this Gigabit switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100) and intelligently adjusts for compatibility and optimal performance. Compact size shell make it ideal for desktops with limited space while it is also rackmountable, convenient and safe. Dynamic LED lights provide real-time work status display and basic fault diagnosis.
  • Superior performance
    The rack-mount size metal case design combined with a safety certified internal power supply make the switch the robust product which is very cost-effective for a less than 16 users environment. Featuring non-blocking switching architecture, TL-SF1016 forwards and filters packets at full wire-speed for maximum throughput. With 10K jumbo frame, the performance of large files transfers is improved significantly.
TP-Link TL-SF1016 - switch - 16 ports
Switch - 16 ports
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
16 x 10/100
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 16 ports
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
16 x 10/100
Status Indicators
Power, link/activity
16 x 100Base-TX RJ-45
Internal power supply
Plug and Play, FCC
44 cm
18 cm
4.4 cm
10 - 90%
78VH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
78VH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
Type: Fast Ethernet
Ports: 16
Managed: No
POE: No
Brand: TP LINK
