The TL-SF1016D Fast Ethernet switch is designed for SOHO (Small Office/Home Office) or workgroup users. All 16 ports support auto MDI/MDIX, no need to worry about the cable type, simply Plug and Play. Moreover, with the energy-efficient technology, the TL-SF1016D can save up to 70% of the power consumption and 70% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
High performance
TL-SF1016D Fast Ethernet switch provides 16 10/100 Mbps auto-negotiation RJ45 ports. All ports support auto MDI/MDIX function, eliminating the need for crossover cables or uplink ports. Featuring non-blocking switching architecture, TL-SF1016D forwards and filters packets at full wire-speed for maximum throughput. With 10K jumbo frame, the performance of large files transfers is improved significantly. And IEEE 802.3x flow control for full duplex mode and backpressure for half duplex mode alleviate the traffic congestion and make TL-SF1016D work reliably. -
TP-LINK Green technology
This TL-SF1016D Fast Ethernet switch features the energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. -
Easy to use
The auto features of this gigabit switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100 Mbps) and intelligently adjusts for compatibility and optimal performance.
- TP-Link TL-SF1016D 16-Port 10/100Mbps Desktop Switch - switch - 16 ports
- Switch - 16 ports
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- MAC Address Table Size
- 1K entries
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- 20 cm x 14.2 cm x 4 cm
- Switch - 16 ports
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- 1K entries
- Status Indicators
- Power, link/activity
- 16 x 100Base-TX RJ-45
- Power Device
- External power adapter
- FCC
- 20 cm
- 14.2 cm
- 4 cm
- 0 °C
- 40 °C
- 10 - 90%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.96 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
