TP LINK 14-Slot Unmanaged Media Converter Chassis 19"
Quicklinx: 897QWS00 Mfr#: TL-MC1400
The TL-MC1400 14-slot rack-mount chassis is specially designed to accommodate 14 TP-Links media converters for central power supply, saving space and power cables. Moreover, to stabilize the performance and extend the lifetime, two cooling fans are installed internally. Together with MC series Gigabit/Fast Ethernet media converters, TL-MC1400 is the ideal solution for your media conversion network.
TP-Link TL-MC1400 - modular expansion base
Modular expansion base
Rack-mountable - 2U
48.2 cm x 35.8 cm x 8.6 cm
8 kg
P/N: TL-SG3210XHP-M2 V2.6, TL-SG3452XP V1
Height (Rack Units)
2U
Installed Modules Qty (Max)
0 (14)
48.2 cm
35.8 cm
8.6 cm
8 kg
Rack-mountable
Expansion Bays
14 (total) / 14 (free) x hot-swap
Internal power supply
10 - 90%
897Q TP LINK TP-Link MC200CM - fibre media converter - 1GbE In Stock £28.10
897Q TP LINK 1000M RJ45 to 1000M Single-Mode SC Fiber Converter In Stock £23.36
897Q TP LINK 1000M RJ45 to 1000M SFP Slot Supp. MiniGBIC Modules Adapter In Stock £16.05
